Making Blinking Eyes Using Switch Layers Problem
ilovelessons
Post by ilovelessons »
Hi I am using MOHO 12 Pro,
I am trying to making blinking eyes using switch layers and I am running into a problem. Please help :) below is what I did -
1. I created 3 pictures ( EYE FULLY OPEN, EYE 1/2 way closed , EYE FULLY CLOSED), I guess we could call the images A, B and C respectively for ease.
2. I put the 3 vector images in a SWITCH layer called BLINK
3. Then I go to the timeline
4. Go to frame 1 and I make A the active child
5. Go to frame 5 and make B the active child
6. Go to frame 8 and make C the active child.
7. I play the animation from the start and only my LAST active child shows (i.e. C)
I swear I saw someone do the same exact thing in thus video below (58 seconds into it)
https://www.youtube.com/watch?v=XzOkiU9jJi8
I am applying the same concept except with eyes. Why is his one changing on the time line and mines isn't. After I make something the active child do I need to PRESS something after?
Thanks again.
Re: Making Blinking Eyes Using Switch Layers Problem
Exactly how do you "make the active child"? Does this create a key?
I do this:
- select switch layer
- in timeline, right-click and choose A, B or C
- this creates a key
- go next frame, repeat.
If a child layer is selected, that will be the only one that shows. As long as you have switch layer keyframes, selecting the switch layer will show the animation.
ilovelessons
Thanks guys ! it worked ! muchas gracias !
De nada.
