Question thats probably been asked
Locked
Buddha
Post by Buddha »
I downloaded the new moho 5 beta and it was my first time using version 5 at all (I didnt download the older beta's). I thought that you could draw new objects on other keyframes and have them appear on that frame. For example: If I had a circle on frame 0, then I set it to fram 6 and drew another circle on the other side of the screen, then I though another circle would appear when it hit frame 6. But instead, I just get the circle on frame 6 to be on all the frames including 0. I was just wondering if there was a newer way in version 5 to animate frame by frame like this.
Lost Marble
Post by Lost Marble »
The points and curves making up the circle exist at all frames, but if you fill the circle at frame 6, the fill will be invisible until frame 6.
Locked
