darwing space
puzzles shum
darwing space
Post by puzzles shum »
i have some drawing on tracing paper how fit the on the screen .when i try to trace them on my pad they come out large and can't fit the hole darwing
Re: darwing space
Tricky. This method requires that your drawing fits the drawing pad. How about scan it in and trace in Moho?
Moho 14.1 Mac Mini Plus OS 13.5
puzzles shum
Re: darwing space
slowtiger wrote:Tricky. This method requires that your drawing fits the drawing pad. How about scan it in and trace in Moho?
is their video on this
Re: darwing space
Scanning is just 'taking a picture' of the drawing. If you don't have a scanner, you can just use a phone camera. After you have your image file, import it to Moho using the Import Image command. Once placed, you can scale it to your desired size. Tip: Set the imported art's layer settings to Don't Render This Layer.
puzzles shum
Re: darwing space
Greenlaw wrote:Scanning is just 'taking a picture' of the drawing. If you don't have a scanner, you can just use a phone camera. After you have your image file, import it to Moho using the Import Image command. Once placed, you can scale it to your desired size. Tip: Set the imported art's layer settings to Don't Render This Layer.
thanks for the help
