Put a texture on an object and stretch the object but....
TinyMage
Post by TinyMage »
Not have the texture leave any whitespace when the shape is distorted.
For instance if I make a circle and put a face texture ( with stretch bitmap option ). If i distort the circle too much the face texture will not be drawn in some places it will leave a white space. Is there any way around this with moho since the object I am working on ( a face ) is much more limited in its range of animation if I cannot find a solution to this.
And if there isnt a way in moho, perhaps another program?
Have you tried using masking?
TinyMage
Post by TinyMage »
jahnocli wrote:Have you tried using masking?
Not sure what that is. I am a little new to moho.
I apply the texture with the stretch option. I don't see any other options then stretch and tile.
Start up Moho. Click on "Help" menu item at the top of the screen.
Take a look at:
Help|Tutorials|4 - Images|4.4 Image textures
...if you haven't already. This may help with your problem.
J
