Moderators: Víctor Paredes , Belgarath , slowtiger
Mike Roberts
Posts: 85 Joined: Tue Sep 22, 2015 2:40 pm
Post
by Mike Roberts » Sun Nov 20, 2016 12:55 am
Anyone know why the gun renders inside out even though it looks good in the preview - one is the render one is the preview window
DK
Posts: 2907 Joined: Sun Aug 08, 2004 10:06 pm
Post
by DK » Sun Nov 20, 2016 1:08 am
Struggling to find a gun anywhere in those pics??
D.K
Posts: 3471 Joined: Fri Oct 29, 2004 6:13 am
Post
by jahnocli » Sun Nov 20, 2016 2:50 am
Right click on the image and open in new tab...
DK
Post
by DK » Sun Nov 20, 2016 3:23 am
Ahhh....thanks jahnocli. Probably a basic question but are all your surface poly's facing outwards? What are you modelling in?
EDIT: Can you post the model of the gun so we can test it?
Cheers
D.K
Post
by jahnocli » Sun Nov 20, 2016 1:30 pm
Nice animation! I love Hellboy.
DK
Post
by DK » Sun Nov 20, 2016 1:46 pm
Hi benny,
The secret is in the z layer settings. This sometimes occurs in Lightwave if you have the camera too close to an object you can see the interior mesh. In Moho, adjust your z layer settings and your render will be a lot cleaner.
See screenshots below:
And the render:
Hope that helps!
Cheers
D.K
Posts: 10622 Joined: Mon Jan 14, 2008 2:20 pm
Post
by synthsin75 » Sun Nov 20, 2016 2:32 pm
Yeah, what DK said. Plus you can change the outlines by changing the stroke width in the style window, when a 3D layer is selected.
DK
Post
by DK » Sun Nov 20, 2016 2:35 pm
Hi Wes,
To get the color/surface material settings on the gun did you just place the .mtl file in the same folder as the .obj?
Cheers
D.K
Post
by synthsin75 » Sun Nov 20, 2016 2:36 pm
DK wrote: Hi Wes,
Cheers
D.K
You have to remove "copy" from the mtl name, so the obj file can find the file name it's expecting. But yes, same folder as obj file.
DK
Post
by DK » Sun Nov 20, 2016 2:55 pm
Thanks Wes.
Cheers
D.K
Mike Roberts
Post
by Mike Roberts » Sun Nov 20, 2016 3:11 pm
Thanks guys! that fixed it in the close - but in the long shot i can't get rid of it... moved things to 5 and 5 - still no dice... is it maybe a camera setting?
DK
Post
by DK » Sun Nov 20, 2016 3:43 pm
Hi benny,
Not getting any rendering probs here when I zoom out and rotate the gun using the same z layer settings of 3. See below.
I just zoomed camera out and rotated the gun.
Cheers
D.K
Mike Roberts
Post
by Mike Roberts » Sun Nov 20, 2016 3:45 pm
Have you tried making the gun that small in frame? It works fine anywhere about 50% of the window and up.
