Change speed of sequence
- Jkoseattle
Probably a simple one: I have built an animation sequence spanning multiple layers, but the entire sequence is too slow. How do I select all the keyframes across all the layers for this little sequence and make them all relatively faster?
Re: Change speed of sequence
If you're using Moho 12, you can use Animation>Consolidate Layer Channels and and show every selected layer on the timeline at once. If you don't have Moho 12, you'll need to use Animation>Rescale Keyframes.
