Idea: Creating a glint effect
sillyanimate
Post by sillyanimate »
I wanted to make a glint effect, basically, it would look like an animated shine that goes over a basic picture, like a badge or coin.
My ideas so far:
-Using masking
-Using gradient with transparency for shine
The problem I have so far is giving the shine almost a blur/glow effect...
Any ideas?
Reference Image:
Don't forget! No one is perfect!
Re: Idea: Creating a glint effect
I did that once. Create some white shape with soft edge effect. If that's not enough, blur the whole layer. Set to about 75% opacity, layer blendig mode to screen. If the blur still isn't soft enough, enlarge the layer. Remember to check the render.
Yes, use a mask.
sillyanimate
Thanks for the advice!
Here is a test run:
Still needs a little work...
