Gradient rendering issue
DK
Post by DK »
I just rendered out an image sequence at 1980 x 1020. The image has a slight gradient from top to bottom. I set the render to .png and I am getting bars of gradient rather than a smooth transition. Hard to see but they are there. I know this as when I import into Vegas and try to render a transition, (fade from black), the bars are being picked up and made worse. Can anyone advise?
See image below:
chucky
Re: Gradient rendering issue
Post by chucky »
DK wrote:Hi,
See image below:
I use a similar pipeline and I don't see bars .
Maybe you could try a little noise on that layer?
DK
Post by DK »
I added a noise grain level of 10 and still get the bars though the noise?
Anyone have any ideas what this might be? The evidence is there?
D.K
Do you have an example file I could see?
DK
Post by DK »
Hi Wes,
I was just preparing the file for you when I noticed I had replaced the sky background with a .png file to save on size. It was the .png file that was causing the bars as I had zoomed in quite close. My bad.
Thanks for responding.
D.K
Glad to hear you got it sorted, David.
DK
Post by DK »
I was also trying to keep memory use down as I was experiencing AS crashes using multi thread rendering. Apparently there may be a small memory leak which I reported on Mantis. Funny how a few little bugs like that can get you extra edgy :) I totally forgot I replaced the vector background with a png :oops:
Cheers and thanks again Wes.
D.K
chucky
Post by chucky »
:D
DK
Post by DK »
Thanks Chucky...I feel a bit like Mulder..."The evidence is there" LOL!
Cheers
D.K
