A couple of ideas: Fit to screen & Batch export to one
gavi dvan
Post by gavi dvan »
I have a couple of ideas, that would help me out quite a lot.
1) Fit to screen <----- Cancel that.. I've been shot down. I am left with the following one idea-
2) Batch export to one
This is what i originally thought "batch export" did, but I was wrong, but it would be nice if I was right. It would be grand to have another option that allowed you to batch export a bunch of MoHo files into one Quicktime file, or whatever. So that you wouldn't have to stitch them together in some other program. That would be neat.
Anyhoo, just some ideas. That is all
This is a block of text that can be added to posts you make.
There is a 255 character limit
myles
Re: A couple of ideas: Fit to screen & Batch export to o
Post by myles »
gavi dvan wrote: 1) Fit to screen
A menu option somewhere which sets the viewpoint to make it fit the current layer. For example, if i'm zoomed right out in the middle of nowhere, then i click the layer "eyes", then click this new magical feature, the screen will suddenly fit my "eyes" layer perfectly, without me having to right click drag, shift right click drag, right click drag, etc etc.
In Moho, that's the Escape key - see the appendix in the manual/helpfile.
Moho - magical features built-in.
Regards, Myles.
-- Groucho Marx
myles
Post by myles »
If you have a scrollwheel mouse, you can also use the scrollwheel to do standard in-out zoom, and set your Moho preferences so that shift-right-drag defines a selection-box zoom area.
Regards, Myles.
-- Groucho Marx
rylleman
Post by rylleman »
myles wrote:[In Moho, that's the Escape key - see the appendix in the manual/helpfile.
That only seems to work with vector layers, not with folder type-layers or bitmaps. When using esc (btw, not a good key to assign a shortcut) with those layers you get the camera view instead.
gavi dvan
Post by gavi dvan »
Myles. You are the man.
