PNG export wrong / last frame error in Flash
Rasheed
Post by Rasheed »
I have experienced two problems that are possible bugs.
1) When I export a rendering of any frame as PNG, the resulting file has transparency where there should be none.
2) When I export to a Flash movie, the last frame remains visible after the movie has looped back to the first frame.
For the files, see this page.
I'm using Mac OS X 10.3.9. The screenshots were made in FireFox 1.5. I use Flashplayer 7, which is presumably also the version of the plugin.
Rasheed
Post by Rasheed »
I just updated to Flashplayer 8, but this didn't make any difference.
Rasheed
Post by Rasheed »
Strangely enough, when I don't check Variable line widths for the export of the SWF file, the problem with the "frozen last frame" doesn't occur. However, I do really want those lines to be of variable width.
Another problem seems to be that the SWF files play back significantly slower than the QT file. This rules out any successful attempts to synchronize sounds in the SWF files. I guess if I would own Macromedia Flash or a similar authoring tool, I could solve this problem by trimming the file size of the SWF file and put some pre-loader in it. But the SWF files exported by Moho are not "web ready" it seems.
Lost Marble
Post by Lost Marble »
It turns out there is a bug in some cases if you render one frame and then save it out as PNG. If you want to redner just one frame as PNG, the workaround is to use the Export Animation menu command, select the PNG format, and set the start and end frames to the same number - the one frame you want.
