Anime Studio 9.2 32 or 64 bit
georox
Post by georox »
Hello,
I'm an Anime Studio 9.2 user and I've just re-installed AS in my new Windows 10 computer. The setup installed two versions: 32 and 64 bit even though my OS is 64 bit, so I guess I only need the 64 bit version, am I right? If so, can I safely uninstall the 32 bit version?computer. The setup installed two versions: 32 and 64 bit but my OS is 64 bit, so I guess I only need that version, am I right? If so, can I safetely uninstall the 32 bit version?
Thanks in advance,
Gianni
Re: Anime Studio 9.2 32 or 64 bit
The 32bit version is the only one which will render to Quicktime, if you have it installed. If you don't have Quicktime, you have no use for the 32bt version and can delete it.
georox
Post by georox »
Thanks slowtiger,
Yes, I need to render to Quicktime but in the meantime I unistalled the 32 bit version. So I guess I need to re-install it and remove the 64 bit version, am I right?
Thanks again,
Gianni
No need to uninstall, both versions co-exist peacefully on your drive. Just make sure you know which version you start.
Additionally, there's a command in the program that lets you switch to the x32 version when you need that feature.
