Point reduction tool changed?
eric1223
Post by eric1223 »
With the point reduction tool, There used to be something called "tolerance angle", something that you could edit, but its not there anymore in 12. So then I checked the manual, but the manual says it still should be there. Idk if this is a error, or if the manual is dated.
Also, ironically, it ADDS points sometimes. :!: :!:
Yeah somethings up...
Re: Point reduction tool changed?
You're right...I see it in ASP 11 but it's not there in Moho 12.
I know they put a lot of work into automatically preserving angles when using the Freehand and Simplify tools, so maybe some of that code was implemented in the Point Reduction tool, deprecating this tolerance feature? I don't know, just guessing.
I'll ask.
