Reference Mask Bug
KuzKuz
Reference Mask Bug
Post by KuzKuz »
Hi, another issue with masks. "Group Mask" settings, on the references groups, is not saved when i saving my scene. If load a scene, the "Group Mask" parameter will be reset all time to "No masking in this group".
Moho file - https://drive.google.com/file/d/0ByiL0b ... sp=sharing
Try set "Hide all" mask group parameter on "G1 ref" layer, save the file, then close the file and load.
Regards.
Re: Reference Mask Bug
I asked about that about a year or so ago and apparently it's not considered a bug. I think it's because that technically isn't a keyframeable option so it stays the same for all references. Something like that anyways.
To work around this, I reference the contents of the group, not the group itself. If the groups are not references of each other, they can have different mask settings. Admittedly, this is a little awkward but it works.
Personally, I think you should be able to set the masking options differently between references too.
KuzKuz
Post by KuzKuz »
Thanks for info.
