Follow path with brushes
SuperSGL
Post by SuperSGL »
Found this by accident (good time to state Im still technically a newbie) I have a wacom tablet and I was testing out some of the brushes, when I use a thick brush look and paint say an S stroke I will then go in and change to the orange stars brush if I place my pen near the beginning of my last line I see a transparent red circle and if I paint over the S it will add the brush stroke of the stars over the original (also leaving the original) I don't even have to paint the entire S just a quick swipe and the new brush will follow the last stroke.
Doesn't always work the same way:
1. Sometimes after creating a stroke and then change the brush it will change that stroke to the new brush I select.
2. Sometimes the entire stroke will be replaced by the new brush
3. Sometimes the new brush will be created over the path of the old brush stroke leaving both
Im using Moho 12 but discovered works the same in ASP 11
Norman McLaren
My Animations
