How to add bones to psd import? [Solved]
Katy133
Post by Katy133 »
I'm using Anime Studio Pro 8. I've created a bone layer with a jpg image (of a creature's tail) inside it. On the bone layer, I've added 3 bones. However, when I try to manipulate the bones, the jpg image doesn't move, only the bones move.
To experiment, I tried adding a vector image in the same bone layer. I manipulated the bones, and the vector image moved, but the psd image still didn't.
I've been reading the AS Pro 8 manual, but it makes no mention about psd imports (regarding bones). I've looked at tutorials that use AS Pro 11, and according to those, my method should work. Is it because I'm using Pro 8? Is there any way to get around this? Please help!
Re: How to add bones to psd import? Issue.
Check the image layer setting, image tab, to make sure "warp using bones" is enabled. If that doesn't do it, select the image layer and use the menu command Bone>Flexi-bind layer.
Katy133
Post by Katy133 »
That worked! I turned on "warp using bones". Thank you soooo much! <3
