Here's the new version -- v8.80 -- https://www.mediafire.com/?ojra97ptsfnprtg
The zip contains two installable directories: for AS11 and Moho12
The main difference between the AS11 and Moho12 version is that the icons have changed because of UI improvements in Moho12. It is possible to install the Moho12 version in AS11 -- the script WILL work -- but the icons will not be optimal.
The key changes since V8.60 are: Three new subtools: Concentric Polygons, Polygon of Triangles and Grid of Triangles; plus support for Moho 12 icon colourisation.
The polygon of triangles and grid of triangles are mainly intended for use in Smart Warp (I'll post more about Smart Warp over the next few days)
Please also see the readme in the .zip
Any problems, please let me know!!
(previous version is here: viewtopic.php?f=12&t=27459)
HS_Shape new Moho12 version
- hayasidist
- funksmaname
Re: HS_Shape new Moho12 version
Thanks Paul. I'm sure I'll get a lot of use out of the triangulated grid using the Moho's new mesh warp.
- funksmaname
Hey Paul, the 'tool' folder appears to be empty in the Moho12 version?
It's in the resources folder, Danny. I'm sure he didn't mean to put it there.
- hayasidist
- hayasidist
version 9 is now available at https://www.mediafire.com/?e7ncez99jxgb3dd ... the .zip is v900, but the .lua and readme are actually 9.02
key changes from V8.80 are:
>> AS/Moho V11 support ended
>> new options for the grid of triangles:
-- the original hex-based (ragged edges) one
-- squares with alternate diagonals
-- squares with diagonals in all the same direction
Because the grids are made of many shapes they take an age to display .. so the initial click / drag creates just the wireframe and the shapes are filled on mouse up.
As ever, please let me know of any problems or feature requests.
Great tool, Paul. I can't live without it for creating smart meshes.
