Moho 12 & CACANi
dueyftw
Moho 12 & CACANi
Post by dueyftw »
Dale
Re: Moho 12 & CACANi
The new Image Sequence layers are not meant for svg import, since these layers wouldn't allow for vector editing (so you could just export your svg to a raster format). Even the old third-party image sequence import menu script didn't handle svg. I can write an svg sequence import script that will keyframe each in a switch.
dueyftw
Post by dueyftw »
synthsin75 wrote:The new Image Sequence layers are not meant for svg import, since these layers wouldn't allow for vector editing (so you could just export your svg to a raster format). Even the old third-party image sequence import menu script didn't handle svg. I can write an svg sequence import script that will keyframe each in a switch.
That would save a ton of work.
Dale
