Del key not deleting points
mystd
Post by mystd »
http://imgur.com/s3CObhN
I've selected that point and I press the delete key and it won't get deleted.
new account: brahrah
mystd
Re: Del key not deleting points
Post by mystd »
I've moved the lines around a bit and this is what AS created when I drew a simple circle:
http://imgur.com/e9zmgnG
mystd
Post by mystd »
Aaaannd Layers are disabled again and only way to fix it is to copy the content to a new file:
http://imgur.com/rjvapyV
Do you have the select points tool selected when trying to delete points?
Are you on frame zero when trying to delete points or create layers?
Do you have drawing tools enabled for only frame zero?
mystd
Post by mystd »
Ahhh ok thank you! So I can only draw when on frame 0 no wonder it didn't work. The option drawing tools enabled for only frame zero should be off this is really confusing for beginners. I'd rather mess up the frames and learn that drawing on different frames than 0 won't change my original than thinking it's a bug because I don't know there is an option to change that.
