Any ideas for the removal of gaps hands and feet? ASP 10
Lusy
Post by Lusy »
Good time everyone. I created character in ASP 10. Have any ideas for the removal of gaps hands and feet?
Image Image
Maybe I can do something with the points and bones? or Layers and bones?
p.s sorry if there was post like that?
Re: Any ideas for the removal of gaps hands and feet? ASP 10
Try rounding the connecting ends and having them overlap more.
Lusy
Post by Lusy »
synthsin75 wrote:Try rounding the connecting ends and having them overlap more.
can I somehow make the legs-end stretching using points?
Sure. Bind points in the legs to the hip bone.
Lusy
Post by Lusy »
synthsin75 wrote:Sure. Bind points in the legs to the hip bone.
how i can do this? I mean comand flexi-bind points doesn't fix/bind points on the hip bone
Fuzatron
Post by Fuzatron »
You can use the "Bind Points" tool to bind specific points to a selected bone.
Lusy
Post by Lusy »
Fuzatron wrote:You can use the "Bind Points" tool to bind specific points to a selected bone.
I did so, but bind points tool works only once. And other points remain without leg bone
Lusy
Post by Lusy »
I solved this problem. I choose the tool select bone (not tool layer bind) and selected need bone. after selection need bone choose the tool bind points. Select the desired point and when the points are selected press spacebar.
Lusy
Post by Lusy »
And it doesn't matter on the same layer or on different drawing. I got like this.
Image Image
my character turned out: the legs, hips and body are on the same layer, and the hands on different layers. (Shoulder, elbow and wrist on separate layers)
