AS-> FBX -> Unity BUGSSSSSS
I just had enough
We spent a week to make it right.
We tried almost all possibilities and their permutation believe in the marketing this should work
Situation is very simple one character and a simple animation with eye blinking mouth yawning.
We never got a perfect animation in Unity
We tried group layers, switch layers, smart bones, without bones every imaginable setup.
All kind of problems comes up in unity. Can see eye, Open and closed eye visible togehter, wrong z order. etc etc etc
We use the unity importer script
You can download our test from here: https://drive.google.com/file/d/0B_pXC7 ... sp=sharing
Is anyone here the AS-> FBX -> Unity scenario ever worked?
Re: AS-> FBX -> Unity BUGSSSSSS
Are you using the unity importer script? The newest one, I mean.
I dont know which one is the last one, I use this: (the date of the file is 10 Nov 2015)
using UnityEngine;
using UnityEditor;
using System;
public class AnimeStudioPostProcessor : AssetPostprocessor
private bool fIsAnimeStudioModel = false;
void OnPreprocessModel()
// resampleRotations only became part of Unity as of version 5.3.
// If you're using an older version of Unity, comment out the following block of code.
// Set resampleRotations to false to fix the "bouncy" handling of constant interpolation keyframes.
try
var importer = assetImporter as ModelImporter;
importer.resampleRotations = false;
catch
void OnPostprocessGameObjectWithUserProperties(GameObject g, string[] names, System.Object[] values)
// Only operate on FBX files
if (assetPath.IndexOf(".fbx") == -1)
return;
for (int i = 0; i < names.Length; i++)
if (names[i] == "ASP_FBX")
fIsAnimeStudioModel = true; // at least some part of this comes from Anime Studio
break;
void OnPostprocessModel(GameObject g)
return;
if (!fIsAnimeStudioModel)
//Debug.Log("*** Not Anime Studio ***");
return;
Shader shader = Shader.Find("Sprites/Default");
if (shader == null)
return;
Renderer[] renderers = g.GetComponentsInChildren<Renderer>();
int straightRenderOrder = shader.renderQueue;
foreach (Renderer r in renderers)
int renderOrder = straightRenderOrder;
if (r.name.Contains("|"))
string[] stringSeparators = new string[] {"|"};
string[] parts = r.name.Split(stringSeparators, StringSplitOptions.None);
int j;
if (Int32.TryParse(parts[parts.Length - 1], out j))
renderOrder += j;
r.sharedMaterial.shader = shader; // apply an unlit shader
r.sharedMaterial.renderQueue = renderOrder; // set a fixed render order
straightRenderOrder++;
I have the same problem:
Does anyone know, where you can obtain the current script?
Which is the current version?
Thank you
Thank you
Make sure you have the latest version of ASP, and create a custom content folder. Inside the custom content folder will be a folder called "Extra Files" where you'll find the latest script.
Not sure what the latest version is as there's no version number noted anywhere in the script.
Just doesnt work
Please somebody who has real practice not just ideas write here
After a week and 245 try I gave up. THIS IS NOT WORKING AND ANIME STUDIO SHOULD FINISH ADVERTISING THIS FEATURE!!!
Yes, thank you for the tip. I think, it tworks on my pc.
@zsolt67
Can you show some screenshots from unity?
What's the problem in unity?
Greetings
@zsolt67
Greetings
What works on your pc? The imported file works like the the boar parts in good Z order the blinking eye blinking open,close, open and yawning with streching mouse?
Can you please send it on captured video.
If really works for you could you please send your unity importer script to compare
here is the video of unity result. Z order not ok. https://drive.google.com/file/d/0B_pXC7 ... sp=sharing
As I said before we tried almost all possible setup, modification trick EVERYTHING. if we can repair Z order problem, the two status of eye visible same time. I we modify something and that problem disappear other comes up.
Are you using Unity 5.3?
Unity importer works fine for me. Here are some steps:
In Unity Assets folder, create a folder titled: "Editor" and place the Anime Studio import script inside of it. Restart Unity.
Import your FBX file. That's all there is too it.
In Anime Studio, make sure you aren't using the Z axis to order your image layers and keep everything flat.
Newest free unity.
Can you please capture the video. Atube catcher is a free program to capture video from screen
Anyone?
He gave you instructions. Have you tried them for yourself?
I made an easy to follow tutorial. I'm using Unity 5.3.5 and AS 11.2
