Workspace animation preview "problem"
ruidelgadoalves
Post by ruidelgadoalves »
Hi there,
I'm sure I'm doing something wrong, but my workspace animation preview does not show the curves of a vector based object.
For instance, I'm animating a simple circle. When I play the animation pressing the button, the circle changes to a polygon between the key frames.
However, if I run the animation through the timeline bar, I can see the changes on the circle between the two points.
Any configuration I'm missing here?
Thanks for your help.
Regards,
Rui A
Re: Workspace animation preview "problem"
If you disable GPU acceleration, the curves will remain smooth in playback. Either way, the final render is not effected.
ruidelgadoalves
synthsin75 wrote:If you disable GPU acceleration, the curves will remain smooth in playback. Either way, the final render is not effected.
Where shall I disable GPU acceleration?
Edit>preferences or display settings.
ruidelgadoalves
synthsin75 wrote:Edit>preferences or display settings.
Not on my MAC version
I've only seen that problem with GPU acceleration. If you're sure you don't have that option, then you don't have an OpenGL-compatible graphics card.
But again, I've never seen AS do that without GPU acceleration. Can you post screen shots of your display quality menu and preferences menu?
