(SOLVED) weird layer behaviour
karip
Post by karip »
Hi all,
I've got this weird problem that I'm not able to figure out.
https://www.dropbox.com/s/3bfnbts781yme ... e.zip?dl=0
On frame 0 there is a blue color and I don't seem to be able to pinpoint where it is.
If I select the shape and deactivate the fill, it gives me this.
However, when I preview the animation, the blue color is not visible. But if I render a preview frame, it is.
If somebody has the time to check out the file and tell me what I've missed, I'd be happy!
Thanks!
Kari
EDIT: It has something to do with shape effects, when I disable it from the display quality, the blue layer disappears. It's somewhere in the cache, but I'm not able to clean it.
Re: weird layer behaviour
you have point colour on using the observed colour (blue - x1EA6BD) and strength variously around 1 for each point.
Select all the points and in the Color Point tool - (default shortcut K) press clear and the observed fill will revert it to the expected mauve (x991657)
karip
Post by karip »
Whoah, I was trying everything I could think of, but that was the key. Thanks a lot! The behaviour was so weird that it was guiding my problem solving all over the place. But just not there, hah!
Great work, thanks for the help.
