Seeing Red in Actions Window
RichardU
Post by RichardU »
I read the manual and couldn't figure out: Why do some items show as Red in the Actions Window?
Thanks,
Richard
Lychee
Re: Seeing Red in Actions Window
Post by Lychee »
I think This is when you actualy use the corresponding bone on the mainline (the bone should also be in red).
RichardU
Post by RichardU »
Right. Seems to be whenever you select a bone it shows you corresponding Actions. I might have chosen green as a highlight color. Red tends to indicate a problem, which is not the case here.
Thanks, Richard
You can change the color to whatever you prefer. For example, because I use the Dark color theme, the color appears gold by default.
For that specific item, I think you need to change the Selection color chip under GUI Colors.
G.
