DRAGON MATRIX v1.0-----Sharing!
sang820
Post by sang820 »
Bigger Installation Instructions image here
:shock:经过长时间的考虑,我和我的朋友决定将“DRAGON MATRIX v1.0”共享。我们经过三年研发才获得这个稳定的版本,这不是件容易的事情,但我相信这会让更多的人在Anime studio找到乐趣 :shock:
DRAGON MATRIX是一个动画增效工具,专注于“细节丰富、成本低廉的表情动画”。
DRAGON MATRIX v1.0是我(施阳)和Def合作开发的基于Anime studio平台(目前正常运行的版本为Anime studio pro 11)运行的第三方动画插件。我已经注册了插件的著作权,对DM拥有完整权限。
DRAGON MATRIX分两部分:
A-代码。用户将其拷贝进As安装程序的指定目录内才会生效。
B-模型。用户向我订制DM模型,然后使用这些模型制作动画。
我会为对DM感兴趣的客户制作一个头模+录制视频解决方案,帮助他们在工作中正确使用DM头模。用户可以通过这些服务评估DM是否适合自己,并且---这是为期三个月的免费服务。(免费服务涉及的视频解决方案会被公开,以帮助更多的人)
download:
https://github.com/defims/dragonmatrix
我的skype: sang820
(我会尽量帮助喜欢DM的朋友,但我只能周六日在线,而且我用中文)
sang820
Re: DRAGON MATRIX v1.0-----Sharing!
Post by sang820 »
:shock: Oh, I seem to quote --- --- video failed Please help withheld revised version link, thank you :shock:
:shock: Wooo!My map size seems to have a problem ---- Help! administrator! :shock:
Awesome! Thanks for sharing!
Thank you very much for sharing this, Sang!
PS: I fixed the Youtube link in your first post and reduced the size of the image, so now it can be fully seen.
For anyone trying this out...it will probably be less confusing if you change the frame one keyframes to an interpolation other than step, on both the bone and vector layer, in the provided demo file.
Rai López
Post by Rai López »
Yes... Suuuper awesome indeed! :shock: I'm just playing a little with the demo file and I'm getting as amazed as I always imagined I would be if I were able to test it someday :). Well, thank you very much for sharing! It's sooo awesome (again) what you did with not so many lines of code... (but with a lot of hard work for sure). Well, thank you again! Now, time to play a little more with it...
sang820
Post by sang820 »
Víctor Paredes wrote:Thank you very much for sharing this, Sang!
:shock: Thanks for the administrator, fix bugs picture, broken links. I knew nothing :shock:
sang820
Post by sang820 »
synthsin75 wrote:For anyone trying this out...it will probably be less confusing if you change the frame one keyframes to an interpolation other than step, on both the bone and vector layer, in the provided demo file.
:shock: Sorry, I will shortly make instructional videos --- please wait :shock:
sang820
Post by sang820 »
Ramón López wrote:Yes... Suuuper awesome indeed! :shock: I'm just playing a little with the demo file and I'm getting as amazed as I always imagined I would be if I were able to test it someday :). Well, thank you very much for sharing! It's sooo awesome (again) what you did with not so many lines of code... (but with a lot of hard work for sure). Well, thank you again! Now, time to play a little more with it...
:shock: Haha, you look very happy. This is what we want to see :shock:
Lychee
Post by Lychee »
Hello guys and girls
Thanks Sang820 for sharing, you and your team are my heroes. :D
But... i'm a PC user, how to install this on a Windows machine ?
Edit: For PC users who use AS11/ 10 (perhaps it's not same for the olders versions), install to:
Windows/ Programs (64x or 86x)/ Smith Micro/ Anime Studio/ Resources/ Support/ Scripts/ Tool/---> df files
Windows/ Programs (64x or 86x)/ Smith Micro/ Anime Studio/ Resources/---> thisapp_pro_splash.ZH_CN.png
Best regards.
Lychee
Post by Lychee »
sang820 wrote: :shock: Sorry, I will shortly make instructional videos --- please wait :shock:
It will be very helpfull because i dont understand how it work.
As you can see above I tried some constructions around my modification of dueyftw and dkwroot method which gives very good results, but it's still difficult to implement with all these bones.
I hope Dragon Matrix can afford to simplified everything.
This looks very interesting. Thanks for sharing it!
I'm going to check it out as soon as I can make some time for it. Can't wait. :)
Lychee wrote:Hello guys and girls
Best regards.
You can install these to your custom user tool folder, which works for both 32 and 64bit. I doubt the splash matters, since it's named as a replacement for the Chinese version of AS. I haven't verified, but the joystick tool looks like just a utility file, so it could probably be put in the utility folder.
strider2000
Post by strider2000 »
Sang820,
That is wonderful news. Thank you so much for sharing. I can't wait to take a look!
sang820
DRAGON MATRIX v1.0-Simple tutorial
Post by sang820 »
Simple to use, common mistakes, you need to pay attention to things=3
