Hi!
It happens that I draw and animate a scene to the end before I animate the camera. And then I realise there are layers that are on another Z-axis as they should.
Now I have to correct EVERY keyframe. Thats very frustrating and kills much of the fun with animating. Is there a trick to correct the Z-Axis vor all keyframes at once?
Thank you!
Anoying Z-Axis problem
Noisefever
Re: Anoying Z-Axis problem
I'm not aware of any method, but I think it should be possible to script this. Search and ask in the script forum.
Noisefever
okay, will do.
Thank you!
Thank you!
If the layers don't have animated layer transformations, relative keyframing or shift+alt translate may work.
Noisefever
Of course they have, that was the problem
but relative keyframing works anyway. I hadn't realised that. I was helped out in another thread but your idea was right. So: thank you too!
