Looping through selected layers
lehtiniemi
Post by lehtiniemi »
I tried to look for a way to access selected layers, all I found was CountSelectedLayers(GroupLayer *group). I tried passing it an argument, like so:
local layerList
moho.document:CountSelectedLayers(layerList)
However, layerList won't contain selected layers after this call. How do I use it or is there some other way?
Re: Looping through selected layers
CountSelectedLayers does not populate the empty variable. You need to assign it a variable:
local selLayerCount = moho.document:CountSelectedLayers(moho.document)
You can also specify a particular group layer instead of the whole document.
To count through them:
for i=0, moho.document:CountSelectedLayers(moho.document)-1 do
lehtiniemi
synthsin75 wrote:CountSelectedLayers does not populate the empty variable. You need to assign it a variable:
Ah, thanks! Hmm but how do I access the selected layers? CountSelectedLayers doesn't tell me which layers are selected.
lehtiniemi wrote:Ah, thanks! Hmm but how do I access the selected layers? CountSelectedLayers doesn't tell me which layers are selected.
     local layer = moho.document:GetSelectedLayer(i)
lehtiniemi
Thanks!!!
