Saving tool button states when switching between tools?
lehtiniemi
Post by lehtiniemi »
When I have for example a checkbox in my tool top bar, its value gets reset when I switch to another tool and back.
Is it possible to save this state so that the value stays the same even if I switch to other tools inbetween?
Re: Saving tool button states when switching between tools?
yes.
load and save prefs
for example
function HS_Test_harness:SavePrefs(prefs)
	prefs:SetBool("HS_Test_harness.trace", self.trace)
	prefs:SetBool("HS_Test_harness.diagnose", self.diagnose)
	prefs:SetFloat("HS_Test_harness.n1", self.n1)
	prefs:SetFloat("HS_Test_harness.n2", self.n2)
	prefs:SetString("HS_Test_harness.uut", self.uut)
end
function HS_Test_harness:LoadPrefs(prefs)
	self.trace = prefs:GetBool("HS_Test_harness.trace", true)
	self.diagnose = prefs:GetBool("HS_Test_harness.diagnose", true)
	self.n1 = prefs:GetFloat("HS_Test_harness.n1", 0)
	self.n2 = prefs:GetFloat("HS_Test_harness.n2", 0)
	self.uut = prefs:GetString("HS_Test_harness.uut", defaultOn)
end
function HS_Test_harness:ResetPrefs()
	self.trace = true
	self.diagnose = true
	self.n1 = 0
	self.n2 = 0
	self.uut =  defaultOn
end
lehtiniemi
hayasidist wrote:yes.
load and save prefs
for example
function HS_Real_Time:SavePrefs(prefs)
	self.useIK = prefs:GetBool("HS_Real_Time.useIK", true)
	self.boneFBF = prefs:GetBool("HS_Real_Time.boneFBF", false)
end
function HS_Real_Time:LoadPrefs(prefs)
	prefs:SetBool("HS_Real_Time.useIK", self.useIK)
	prefs:SetBool("HS_Real_Time.boneFBF", self.boneFBF)
end
function HS_Real_Time:ResetPrefs()
	HS_Real_Time.useIK = true
	HS_Real_Time.boneFBF = false
end
Thanks. Again. :)
error in original post -- updated -- please disregard the post to which you replied
