how can i change the direction of the knee
liukang0801
Post by liukang0801 »
you guys, help me..
i wanna change the direction of the gorilla knee as the image below, but i dont know how, i have that rig, but i can't do anything now.
the rig in animestudio 11..
how can i do that..help me.
i dont know why cant sê the image..so i bring this link here, help me.
https://drive.google.com/file/d/0BwHpro ... sp=sharing
Re: how can i change the direction of the knee
your image is "protected": this error when trying to access it: "The file you want to access is a Google Docs, Sheets, or Slides file, which means the owner of the file has to give you permission to open it."
liukang0801
hayasidist wrote:your image is "protected": this error when trying to access it: "The file you want to access is a Google Docs, Sheets, or Slides file, which means the owner of the file has to give you permission to open it."
this link for the image..help me,guy
Just rotate the forearm bone until it snaps the other way.
liukang0801
synthsin75 wrote:Just rotate the forearm bone until it snaps the other way.
oh..thank you so much..i did it...by the way, can you switch ik fk in animestudio 11 ?
Yes, for the gorilla's arms you will have to remove the bone targets from the forearm bones. Targeting is animated, so you can restore it at any time.
liukang0801
synthsin75 wrote:Yes, for the gorilla's arms you will have to remove the bone targets from the forearm bones. Targeting is animated, so you can restore it at any time.
oh..wow..thank you, i dit it..thank you so much more..^^..
eric1223
Post by eric1223 »
Actually, There is a way to do this without removing the target bone. With the Transform Bone tool, click hold the forarm. Drag either to the left or to the right. until you see a change. It might work if you pull it in the opposite direction that you want to go.
eric1223 wrote:Actually, There is a way to do this without removing the target bone. With the Transform Bone tool, click hold the forarm. Drag either to the left or to the right. until you see a change. It might work if you pull it in the opposite direction that you want to go.
Yeah, I told him that earlier. Removing the targets was for restoring free FK/IK.
eric1223
Post by eric1223 »
synthsin75 wrote:Yeah, I told him that earlier. Removing the targets was for restoring free FK/IK.
I'm sorry synth. I actually caught this earlier on and tried to delete that post before it was read, but I didn't confirm the delete. Welp.....This is embarassing. :oops:
No problem.
