How to remove sketchy effect once you applied it ?
saintbe
Post by saintbe »
Hi AS fans !
As you can see in the video below I added a sketchy effect to it ... How do I get rid of it ?
The option to make sketchy is always there even if it's already applied ... but I see no way to undo it :
Cheers,
-Kim.
Re: How to remove sketchy effect once you applied it ?
Layer settings, Vector tab.
saintbe
Post by saintbe »
Simple enough :oops:
Thanks !
sbtamu
Post by sbtamu »
I understand the OP concern. Once you you use that script it turns everything into sketchy but there is no way to undo it after you do a save unless you go through every freaking layer and undo it manually in each layer. I think this script should have an option to undo it after a save with out going into each layer and doing it manually.
Sorry for bad animation
You can select multiple layers and make the change all at once.
