Smartbones only allowing 2 actions per bone??!?!?!
sillyanimate
Post by sillyanimate »
Hi, I am a Anime Studio Pro 9 user
You see I just smartbones to hide and fix seams....
I use bone constraints you see, so since smartbones isn't 100 perfect i want to make more than 2 actions per smartbone
The only problem is that after i put in the name of bone and the number 3, it doesn't work... I can tell because the bone isn't highlighted
I spelt the bone name correctly and only put one space after the 3 HELP!?!??!
Don't forget! No one is perfect!
styrofoamhead
Re: Smartbones only allowing 2 actions per bone??!?!?!
Post by styrofoamhead »
Smart bones only allow for 2 actions per bone.
sillyanimate
What about later versions (10 & 11?)
dkwroot
Post by dkwroot »
All versions of AS only allow two actions per bone. One for rotating clockwise and another for counter-clockwise.
still 2... and, as dkwroot said, those 2 smartbone actions are intended to be one each for positive (>0) angles of rotation and negative (<0) angles of rotation. Or you can have just one action for the whole range of rotations including >360
but within an action you can control many things - including other bones...
so if you wanted to ask "how many different things can you make one smartbone do?" the answer is "that's limited only by your imagination!"
sillyanimate
wait how do you use smartbones to control other bones?!?!?!
Also could smartbones work for a 360 degrees rotation like for 2.5d?
1: see ASP11.2 manual pages 105 to 117.
2: see viewtopic.php?f=13&t=28802
that should get you started. try a few things... then if/when you get stuck just ask!
sillyanimate
I am Anime Studio Pro 9 user....
ASP9 manual talks about smart bones on pages 77 to 89
sillyanimate
Good to know
I wish in Anime Studio Pro 9 supports smartbones with groups
sillyanimate wrote:Good to know
That feature was added in 9.5 and really changed the way we rig.
