Backward setting on Elastic?
- strider2000
Can anyone tell me how to set the backward setting on elastic interMode in a script?
Re: Backward setting on Elastic?
Didn't know, so I did a quick test. Turns out you just have to add 10000 to your bounce count value (interp.val1). Seems 1000 is as high as you can set it, so that would be 11000 if you're setting it backwards.
- strider2000
Wow thanks. I had seen the 1000x and so I added "1000" and it didn't work
Doh that was dumb on my part. I thought I was doing something wrong. I should have thought a little more. + 10000 not + 1000
How embarrassing. As my mom used to say, "If it was a snake it would have bitten me." Thanks for the help. synthsin75. It's much appreciated.
I probably would have made the same mistake if I hadn't tried the max value.
Glad I could help.
Glad I could help.
