11.2-Node name BUG
sang820
11.2-Node name BUG
Post by sang820 »
:shock: In As11.2, to the node named,Using the first two names, the model is destroyed. (Curvature, remove nodes)
11.1 no exception. I use As11.1 named node, using 11.2 open, the same BUG. :shock:
:shock: With the magnet tool, named node becomes very important. ~ Thank you wanted to fix :shock:
Re: 11.2-Node name BUG
Hi, Sang
Could you create a video showing the Bug?
Thanks.
sang820
Post by sang820 »
Víctor Paredes wrote:Hi, Sang
Thanks.
:shock: http://www.tudou.com/programs/view/qlu9MsMouYI/ :shock:
:shock: I hope you can see the video, because I can not log in Youtube. I use Mac pro, As10-11.2 genuine upgrade. :shock:
Thank you
Wow, that's a weird bug.
