Deactivate an action?
strider2000
Post by strider2000 »
Is there a correct way to programmatically return to the --- Mainline ---. I know how to activate an action. I tried Activating "Mainline" and "--- Mainline ---" but that didn't seem to work. It does seem that if I create a junk action and then delete it then I accomplish what I want, but that really doesn't seem to be the elegant approach :o
Stan
Re: Deactivate an action?
Post by Stan »
If you don't care for older versions (earlier than 10.0), then you can just use this:
moho.document:SetCurrentDocAction(nil)
However, if you do care for older versions, here is the correct way to do it (complete button-script):
-- Provide Moho with the name of this script object
ScriptName = "SZ_ActivateMainline"
SZ_ActivateMainline = {}
function SZ_ActivateMainline:Name()
	return "Activate Mainline"
end
function SZ_ActivateMainline:Version()
	return "1.0"
end
function SZ_ActivateMainline:Description()
	return "Quit edit action and go to mainline"
end
function SZ_ActivateMainline:Creator()
	return "Stan aka Vodka"
end
function SZ_ActivateMainline:UILabel()
end
-- The guts of this script
function SZ_ActivateMainline:IsEnabled(moho)
	if moho.layer:CurrentAction() ~= "" then
		return true
	end
	return false
end
function SZ_ActivateMainline:IsRelevant(moho)
	return true
end
function SZ_ActivateMainline:Run(moho)
		local version = 9.0
		if moho.AppVersion ~= nil then
			local sVersion = string.gsub(moho:AppVersion(), "^(%d+)(%.%d+)(%..+)", "%1%2")
			version = tonumber(sVersion)
			-- print(sVersion)
		end
		if version >= 10.0 then
		end
		moho.layer:ActivateAction(nil)
		moho.layer:UpdateCurFrame()
		moho:UpdateUI()
	end
end
And here's the icon: Image
strider2000
Much thanks Stan :D Very much appreciated. 10+ is good for me.
