I have a bunch of spatter brushes I want to use in a frame by frame animation. Maybe 3 different brushes in one frame 3 different brushes in the next frame and so on with up to 14 different brushes. Is there a fast way to do this? Instead of switching brushes each time sometimes 3 or more brushes in the same frame.
Thanks.
FBF quick brush switching?
- uncle808us
http://uncle808s.blogspot.com
Re: FBF quick brush switching?
Hi, I'm not quite sure what you mean.
You can make a multibrush, which is a folder of different brushes that switch in order or randomly.
Here is an example with Splatter brushes, using that method.
You can buy an add-on pack from Smith Micro that has all those brushes,including splatter.
Actually it is pretty hard n see the splatters in there ,but I assure you there is a good one in the pack, I'll show you a images when I get back home.
- uncle808us
Yes I figured it out Thanks.
