Clear Console
Clear Console
Is it possible to clear the ASP Lua console?
My opinions and comments do not represent those of my employer.
http://www.ernestpchan.com
http://www.zazzle.com/gopuggo
Re: Clear Console
Just close it. It will be reset the next time it is invoked. Reloading scripts (ctrl+alt+shift+L) closes it too.
Re: Clear Console
But if you would like to clear it without closing? Is it possible?
Making a script which gives info in the console. Would like to present the data clean without all old info there.
Re: Clear Console
The console displays a limited number of lines, so you could probably print enough new lines "\n" to have your new output be the only thing showing. It would just have a lot of empty space above it, but the console should scroll down to the last output, so it shouldn't effect the end user.
