Add bones while seeing points of vector layers
ernpchan
Post by ernpchan »
Is it possible to add bones while seeing the points of my vector layers? It would be helpful to see the vector points so I know where to draw my bones.
My opinions and comments do not represent those of my employer.
http://www.ernestpchan.com
dkwroot
Re: Add bones while seeing points of vector layers
Post by dkwroot »
To the right of your layer name you should see a small triangle facing downward, click on the triangle. A menu should pop up, you should see a checkbox for "Paths" click it on and then press the apply button.
ernpchan
Post by ernpchan »
Thanks!
What the..? I did not know you could do that. :shock:
That's going to be useful. Thanks for the tip.
G.
ITAK
Post by ITAK »
dkwroot wrote:To the right of your layer name you should see a small triangle facing downward, click on the triangle. A menu should pop up, you should see a checkbox for "Paths" click it on and then press the apply button.
... or just "Display Quality" (bottom right corner of main window) -> "Wireframe"
