[SOLVED] No effect of "transform layer (M)" tool in 0
Bax
Post by Bax »
Hi!
System
Anime Studio Pro 11, Win 8.1
Test file
I uploaded the file with the strange behavior here:
https://www.dropbox.com/s/x9qvjrvyh8ml8 ... anime?dl=0
Problem
very strange "transform layer (M)" tool behavior for me:
  • I am not able to move a certain bones layer with the "transformation tool (M)" at frame 0.
  • I am also not able to move any vector layer in that bones layer with the same "transformation tool (M)".
  • when I chose a frame higher than frame 0, it jumps to the new position but is still not visible in frame 0.
  • I made another bones layer with a vector layer in it and everything works fine. But when I drag this moving vector layer into the "no movement at 0" layer I also can't move it.
  • When I drag the not moving vector layer to the new bones layer I can move it again at 0 with the "transform layer tool".
  • other layer tools (like rotate) work normally in that strange bones layer.
Greetings
Bax
Re: No effect of "transform layer (M)" tool in 0
The bone layer that won't transform on frame zero has been moved on the sequencer, back one frame. So any layer inside it is also back one frame. Aligning its green timeline arrow with frame one will fix it.
Bax
Re: [SOLVED] No effect of "transform layer (M)" tool in 0
Post by Bax »
So easy, thanks a lot! It works again!
cynthia
Post by cynthia »
[quote="synthsin75"]The bone layer that won't transform on frame zero has been moved on the sequencer, back one frame. So any layer inside it is also back one frame. Aligning its green timeline arrow with frame one will fix it.[/quote]
Brilliant! thank you. How do you know all this obscure stuff?
cynthia wrote:
synthsin75 wrote:The bone layer that won't transform on frame zero has been moved on the sequencer, back one frame. So any layer inside it is also back one frame. Aligning its green timeline arrow with frame one will fix it.
I've just been using Moho for about 10 years. It always helps troubleshooting when people post the files. Saves a lot of guesswork.
Keeping up with this forum also helps me stay up on solutions and techniques.
cynthia
Post by cynthia »
Well thank you very much for your expertise and willingness to share it :-)
