how to make dashed lines?
undo
Post by undo »
hi,
i want to do dashed lines but in moho that does not seem to be possible, is it?
Well of course one could put very much on the line and make every second line in between invisible.
But thats too mauch work and would look shitty too, i fear.
Any better way?
simple clickable linestyle would be neat :)
ulrik
Post by ulrik »
You can make a brush to use with the outlinesetting in style window, you need to do it as an .png with transparency in it so the "in betweens" not will be filled with some background color though.
Then there is settings there to make the frequence to your liking
undo
Post by undo »
thanks, will this only work with straight lines or also with curves?
ulrik
Post by ulrik »
In the brushes window you can choose to align the brushes to follow your curves
undo
Post by undo »
very nice, thanks again :)
