Check version or build
ernpchan
Post by ernpchan »
Is there a way to check version or build number? I've done a search for build and version on the doc site and only found a way to check between Pro and Debut.
My opinions and comments do not represent those of my employer.
http://www.ernestpchan.com
http://www.zazzle.com/gopuggo
Stan
Re: Check version or build
Post by Stan »
There is a method AppVersion for the "moho" object. It is available since 9.5, and it returns a string, so if you want to check for some compatibility you may need to convert it to a number.
And if you didn't mean to programmatically check the app version with Lua, then just use the "Help > About..." menu. :)
sbtamu
Post by sbtamu »
Right click on any saved anme file and open with notpad and read the 1st few lines of code. It will tell you what version it is.
Sorry for bad animation
ernpchan
Post by ernpchan »
Thanks Stan! That's perfect.
