Sorry to throw more at you. but as far as I can tell, the lasso mode for point selection is DOA. This also seems to be the case in the "bind points"tool. Just for the heck of it, I again tried to use the lasso tool to select a very, very dense scribbly drawing I did with my pallette with the default freehand settings, and succeeded in crashing the program. I haven't been able to duplicate this. It's possible I hit the right click button on the pen while tapping, so it might have been the 2-mouse-button crash, but I don't believe so.
When going from freehand (and maybe other drawing modes) to translate, and if autoweld is checked in translate, it seems to autoweld points across all layers when you move something. I'm not entirely sure of the consitency of my results here, and am wondering if there is some interaction with having previously run the autoweld script. I have to go do some paying work now, so I'll test that a bit more later tonight.
Also, a small thing, you can't resize the horizontal dimensions of the main window by grabbing the sides, but only from the corners.
That said, great, great stuff. I haven't got to a 10th of the new features yet.
Lasso Woes, etc
- Lost Marble
Re: Lasso Woes, etc
Yes, the lasso function has a serious bug in beta 1. We'll have that fixed for beta 2.7feet wrote:Sorry to throw more at you. but as far as I can tell, the lasso mode for point selection is DOA. This also seems to be the case in the "bind points"tool.
Hmm, I'm not sure what to say about that. It shouldn't do that, so if you can find a repeatable example where that happens, please let us know.When going from freehand (and maybe other drawing modes) to translate, and if autoweld is checked in translate, it seems to autoweld points across all layers when you move something. I'm not entirely sure of the consitency of my results here, and am wondering if there is some interaction with having previously run the autoweld script. I have to go do some paying work now, so I'll test that a bit more later tonight.
You actually can resize the window horizontally, but the cursor isn't changing to the window resize cursor - it stays as the current tool cursor, so it isn't clear when you're in the right place to resize the window. So, the bug is actually the cursor appearance, not the actual window resizing.Also, a small thing, you can't resize the horizontal dimensions of the main window by grabbing the sides, but only from the corners.
