AS 11 X64 MOV output solution(without Alpha channel)
chunyang
Post by chunyang »
I found the win x64 version comes only MP4 video output format and avi, not very good format, I worked out a solution
I offer you to download this video.xml file, you can replace the original, which added a few lines of code. Make sure the computer before replacing installed the latest version of quicktime . If you can not start as11 after replacing , need to restart your computer. Note that the backup of the original XML to avoid problems. Also try using h264 AAC mode output, MOV with Alpha channel I had no solution.
the video.xml file is here:http://pan.baidu.com/s/1c0k9isK
Replace Location: Close software to MediaPlugins / P1_MPMediaFoundation
Have fun!
