I have a character with a walk cycle, which includes layer switching.
In selecting keyframes to repeat a walk cycle, the cycle repeats properly, but the character's hands, which are controlled by switch layers, only switch in the first instance of the cycle. The switching function does not repeat further in the timeline. I tried cycling the switch layers by themselves, with no success.
Does the cycle repeat only work with bone layers? If so, I suppose I can create bones for the hand movements, but it would be nice if I can cycle the switch layer function, too.
How Do I Cycle Switch Layers?
Re: How Do I Cycle Switch Layers?
No problem with cycling switch keyframes here. You don't have any switch keyframes after the cycle frame, do you? That would end the cycle.
Copy the first switch key of the cycle to the end and set it to cycle.
I tried copying the first switch key to the end of the cycle, and it worked, thank you. I did find I had to set a separate cycle in the appropriate switch layer to match the cycle I had set in the bone layer, as there were no switch keys in the bone layer. As an alternative, I created a separate bone in the bone layer to control the switch layer. Then when I set a cycle in the bone layer it would already include the switch layer keyframes for that bone.
So do bone layer cycles and switch layer cycles have to be set separately?
Cycles can only be set for 1 layer at a time, if you want animation to loop which is made of several channels, you have to cycle each channel.
- funksmaname
which is pretty annoying.slowtiger wrote:Cycles can only be set for 1 layer at a time, if you want animation to loop which is made of several channels, you have to cycle each channel.
Instead, I would probably copy the animation into a smart bone, and just cycle that?
