Bone locking still doesn't work in 5.3.1
Rasheed
Post by Rasheed »
I downloaded the new version of Moho 5.3.1, because in 5.3 I couldn't lock bones. But that problem hasn't been solved, it seems. If I check the lock bone checkbox, the check disappears as soon as I click in the Timeline window (see screenshots below).
_______
Image Image
_______
Moho 5.3.1., Mac OS X 10.3.9
Toontoonz
Post by Toontoonz »
Where did you get version 5.3.1?
I don´t see it listed in the forum announcements or faq----or did I miss it? :D
Rasheed
Post by Rasheed »
You missed it. See this post by Lost Marble.
Toontoonz
Post by Toontoonz »
Rasheed - now I found the 5.3.1 update notice:
http://www.lostmarble.com/forum/viewtopic.php?t=2780
"If you're experiencing this problem, please re-download Moho to get a fix."
I tried 5.3.1 - Still seem to be problems with locking bones and dynamics (or something) on bones still. Had a chain of 4 bones: parent at one end, others linked, the last bone in the chain was locked. Parent on one end, locked on the other end. The only bone in the chain that would move is the parent bone. All others locked. Perhaps this is the way it is supposed to be now.
Or if the parent bone had dynamics on it and no other bones were locked or had dynamics on them, then only the parent bone would move - others locked.
Rasheed, I could get the same "where did the locked bone checkmark go?" results on my PC, but maybe that is the way it is supposed to be now.
I got it by locking the parent bone. Once out of the 0 frame, the check mark disappeared. But maybe this is the way it is supposed to be - one can´t lock the parent bone. Perhaps your situation was different than mine?
I could not get Moho to crash like before, but don´t want to do anymore testing on Moho because I have already spent too much time Moho testing.
Rasheed
Post by Rasheed »
Well, I reinstalled version 5.2.1 and the result was exactly the same.
This leads me to conclude that:
One cannot lock a parent bone, only child bones.
Of course, I've reinstalled version 5.3.1 again.
Toontoonz
Post by Toontoonz »
That´s what I was thinking that, that´s the way it always was. I guess one could lock the parent bone in place (so it can´t tilt back and forth), if one wanted, by using angle constraints in the bone dynamics.
Did you get a chance to test the other scenerios I tested in my post above to see if it was an error on my part and not a new situation 5.3.1?
Rasheed
Post by Rasheed »
In my case Moho never crashed from using these files, so I can't compare.
Lost Marble
Post by Lost Marble »
Rasheed, can you show us a sample file of this situation, and tell us which bone is the one that can't be locked?
Rasheed
Post by Rasheed »
I have created a file with three skeletons, each controlling three balls on top of eachother. Each ball has a bone and the bottom bone is the parent, the one above a child, and the one above that a child of a child.
[skeleton 2] [skeleton] [skeleton 3]
In [skeleton] I try to lock the bottom bone, which I cannot do.
In [skeleton 2] I try to lock the middle bone, which I can do.
In [skeleton 3] I try to lock the top bone, which I can do.
Here is the file:
application/x-vnd.lm_mohodoc
version 14
### Created in Moho version 5.3.1, � 1999-2005 Lost Marble
### Created: Sat Dec 10 18:53:11 2005
### static values
dimensions 320 240
frame_range 1 18
fps 24
back_color 234 234 234 255
noise_grain 0
allow_3d true
depth_sort false
distance_sort false
depth_of_field false 2 1 0.05
stereo_separation -1
extra_swf_frame false
soundtrack ""
### styles
### animated values
camera_track
	keys 1
		0 0 0.1 0.5 0 0 1.7321
camera_zoom
	keys 1
		0 0 0.1 0.5 1
camera_roll
	keys 1
		0 0 0.1 0.5 0
camera_pan_tilt
	keys 1
		0 0 0.1 0.5 0 0
### layers
layer_type 4
	### generic layer values
	name "Skeleton"
	quality_flags 1022
	origin 0 0
	parent_bone -2
	visible true
	render_only false
	edit_only false
	scale_compensation true
	rotate_to_follow false
	face_camera false
	masking 0
	blend_mode 0
	camera_immune false
	dof_immune false
	### transforms
	translation
		keys 1
			0 0 0.1 0.5 0 0 0
	scale
		keys 1
			0 0 0.1 0.5 1 1 1
	rotation_x
		keys 1
			0 0 0.1 0.5 0
	rotation_y
		keys 1
			0 0 0.1 0.5 0
	rotation_z
		keys 1
			0 0 0.1 0.5 0
	flip_h
		keys 1
			0 0 0.1 0.5 false
	flip_v
		keys 1
			0 0 0.1 0.5 false
	shear
		keys 1
			0 0 0.1 0.5 0 0 0
	### layer effects
	### bone layer values
	expanded false
	group_mask 0
	depth_sort false
	distance_sort false
	skeleton
		binding_mode 2
		bones 3
			"" -1 -1 1 -1 1 1 -1 1 false 0.539037 1 0 0
			false -1.221731 1.221731
				keys 1
					0 0 0.1 0.5 false
			2 2 1
				keys 1
					0 0 0.1 0.5 -0.036377 -0.992092
				keys 2
					0 0 0.1 0.5 1.570611
					7 0 0.1 0.5 1.047198
				keys 1
					0 0 0.1 0.5 1
				keys 1
					0 0 0.1 0.5 false
				keys 1
					0 0 0.1 0.5 0 0
				keys 1
					0 0 0.1 0.5 0
			"" 0 -1 1 -1 1 1 -1 1 false 0.254758 1 -0.284398 -0.006667
				keys 1
					0 0 0.1 0.5 false
			2 2 1
				keys 1
					0 0 0.1 0.5 0.823435 0.00346
				keys 2
					0 0 0.1 0.5 6.27039
					7 0 0.1 0.5 6.806784
				keys 1
					0 0 0.1 0.5 1
				keys 1
					0 0 0.1 0.5 false
				keys 1
					0 0 0.1 0.5 0 0
				keys 1
					0 0 0.1 0.5 0
			"" 1 -1 1 -1 1 1 -1 1 true 0.181983 1 -0.198359 -0.005882
				keys 1
					0 0 0.1 0.5 false
			2 2 1
				keys 1
					0 0 0.1 0.5 0.462894 0.009316
				keys 2
					0 0 0.1 0.5 0.012974
					7 0 0.1 0.5 0.523599
				keys 1
					0 0 0.1 0.5 1
				keys 1
					0 0 0.1 0.5 false
				keys 1
					0 0 0.1 0.5 0 0
				keys 1
					0 0 0.1 0.5 0
	### sub-layers
	layer_type 1
		name "Layer 1"
		quality_flags 1020
		origin 0 0
		parent_bone -1
		visible true
		render_only false
		edit_only false
		face_camera false
		masking 0
		blend_mode 0
		camera_immune false
		dof_immune false
		### transforms
		translation
			keys 1
				0 0 0.1 0.5 0 0 0
		scale
			keys 1
				0 0 0.1 0.5 1 1 1
		rotation_x
			keys 1
				0 0 0.1 0.5 0
		rotation_y
			keys 1
				0 0 0.1 0.5 0
		rotation_z
			keys 1
				0 0 0.1 0.5 0
		flip_h
			keys 1
				0 0 0.1 0.5 false
		flip_v
			keys 1
				0 0 0.1 0.5 false
		shear
			keys 1
				0 0 0.1 0.5 0 0 0
		### layer effects
		### mesh layer values
		noisy_shapes false
		noisy_lines false
		animated_noise false
		noise_amp 0.033333
		noise_scale 0.133333
		extra_lines 0
		gap_filling false
		fill_texture ""
		line_texture ""
		mesh
			points 4
					keys 1
						0 0 0.1 0.5 -0.03803 -0.456362
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 0
					keys 1
						0 0 0.1 0.5 0.228181 -0.722573
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 1
					keys 1
						0 0 0.1 0.5 -0.03803 -0.988785
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 2
					keys 1
						0 0 0.1 0.5 -0.304241 -0.722573
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 3
			curves 1
				4 true
					0 true
						keys 1
							0 0 0.1 0.5 0.391379
					1 true
						keys 1
					2 true
						keys 1
					3 true
						keys 1
			shapes 1
				"" false true true true
					4
						0 0
						0 1
						0 2
						0 3
						false
							keys 1
								0 0 0.1 0.5 1 1 1 1
						false 0.004167
						false
							keys 1
								0 0 0.1 0.5 0 0 0 1
						false
						6.283185
						0.25
						true
						-1
						-1
						-1
			groups 0
	layer_type 1
		name "Layer 2"
		quality_flags 1020
		origin 0 0
		parent_bone -1
		visible true
		render_only false
		edit_only false
		face_camera false
		masking 0
		blend_mode 0
		camera_immune false
		dof_immune false
		### transforms
		translation
			keys 1
				0 0 0.1 0.5 0 0 0
		scale
			keys 1
				0 0 0.1 0.5 1 1 1
		rotation_x
			keys 1
				0 0 0.1 0.5 0
		rotation_y
			keys 1
				0 0 0.1 0.5 0
		rotation_z
			keys 1
				0 0 0.1 0.5 0
		flip_h
			keys 1
				0 0 0.1 0.5 false
		flip_v
			keys 1
				0 0 0.1 0.5 false
		shear
			keys 1
				0 0 0.1 0.5 0 0 0
		### layer effects
		noisy_shapes false
		noisy_lines false
		noise_amp 0.033333
		extra_lines 0
		gap_filling false
		fill_texture ""
		line_texture ""
		mesh
			points 4
					keys 1
						0 0 0.1 0.5 -0.042991 0.085981
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 0
					keys 1
						0 0 0.1 0.5 0.072753 -0.042991
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 1
					keys 1
						0 0 0.1 0.5 -0.042991 -0.171963
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 2
					keys 1
						0 0 0.1 0.5 -0.158735 -0.042991
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 3
			curves 1
				4 true
					0 true
						keys 1
							0 0 0.1 0.5 0.351238
					1 true
						keys 1
							0 0 0.1 0.5 0.436108
					2 true
						keys 1
					3 true
						keys 1
			shapes 1
					4
						0 0
						0 1
						0 2
						0 3
						false
							keys 1
								0 0 0.1 0.5 1 1 1 1
						false 0.004167
						false
							keys 1
								0 0 0.1 0.5 0 0 0 1
						false
						6.283185
						0.25
						true
						-1
						-1
						-1
			groups 0
	layer_type 1
		name "Layer 3"
		quality_flags 1020
		origin 0 0
		parent_bone -1
		visible true
		render_only false
		edit_only false
		face_camera false
		masking 0
		blend_mode 0
		camera_immune false
		dof_immune false
		### transforms
		translation
			keys 1
				0 0 0.1 0.5 0 0 0
		scale
			keys 1
				0 0 0.1 0.5 1 1 1
		rotation_x
			keys 1
				0 0 0.1 0.5 0
		rotation_y
			keys 1
				0 0 0.1 0.5 0
		rotation_z
			keys 1
				0 0 0.1 0.5 0
		flip_h
			keys 1
				0 0 0.1 0.5 false
		flip_v
			keys 1
				0 0 0.1 0.5 false
		shear
			keys 1
				0 0 0.1 0.5 0 0 0
		### layer effects
		noisy_shapes false
		noisy_lines false
		noise_amp 0.033333
		extra_lines 0
		gap_filling false
		fill_texture ""
		line_texture ""
		mesh
			points 4
					keys 1
						0 0 0.1 0.5 -0.039684 0.468887
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 0
					keys 1
						0 0 0.1 0.5 0.042784 0.376994
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 1
					keys 1
						0 0 0.1 0.5 -0.039684 0.285102
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 2
					keys 1
						0 0 0.1 0.5 -0.122152 0.376994
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 3
			curves 1
				4 true
					0 true
						keys 1
					1 true
						keys 1
					2 true
						keys 1
					3 true
						keys 1
			shapes 1
					4
						0 0
						0 1
						0 2
						0 3
						false
							keys 1
								0 0 0.1 0.5 1 1 1 1
						false 0.004167
						false
							keys 1
								0 0 0.1 0.5 0 0 0 1
						false
						6.283185
						0.25
						true
						-1
						-1
						-1
			groups 0
layer_type 4
	name "Skeleton 2"
	quality_flags 1022
	origin 0 0
	parent_bone -2
	visible true
	render_only false
	edit_only false
	face_camera false
	masking 0
	blend_mode 0
	camera_immune false
	dof_immune false
	### transforms
	translation
		keys 2
			0 0 0.1 0.5 -0.658087 0 0
			7 0 0.1 0.5 -0.658087 0 0
	scale
		keys 1
			0 0 0.1 0.5 1 1 1
	rotation_x
		keys 1
			0 0 0.1 0.5 0
	rotation_y
		keys 1
			0 0 0.1 0.5 0
	rotation_z
		keys 1
			0 0 0.1 0.5 0
	flip_h
		keys 1
			0 0 0.1 0.5 false
	flip_v
		keys 1
			0 0 0.1 0.5 false
	shear
		keys 1
			0 0 0.1 0.5 0 0 0
	### layer effects
	expanded false
	group_mask 0
	depth_sort false
	distance_sort false
	skeleton
		binding_mode 2
		bones 3
				keys 1
					0 0 0.1 0.5 false
			2 2 1
				keys 1
				keys 4
					12 0 0.1 0.5 1.570611
					13 0 0.1 0.5 1.047198
				keys 1
					0 0 0.1 0.5 1
				keys 1
					0 0 0.1 0.5 false
				keys 1
					0 0 0.1 0.5 0 0
				keys 1
					0 0 0.1 0.5 0
			"" 0 -1 1 -1 1 1 -1 1 true 0.254758 1 -0.284398 -0.006667
				keys 1
					0 0 0.1 0.5 false
			2 2 1
				keys 1
				keys 4
					0 0 0.1 0.5 6.27039
					7 0 0.1 0.5 6.27039
					12 0 0.1 0.5 6.27039
					13 0 0.1 0.5 6.806784
				keys 1
					0 0 0.1 0.5 1
				keys 3
					0 0 0.1 0.5 false
					7 0 0.1 0.5 true
					13 0 0.1 0.5 false
				keys 3
					0 3 -1 -1 0 0
					7 3 -1 -1 -0.036277 -0.453055
					13 3 -1 -1 -0.036277 -0.453055
				keys 3
					0 3 -1 -1 0
					7 3 -1 -1 1.557816
					13 3 -1 -1 1.557816
			"" 1 -1 1 -1 1 1 -1 1 false 0.181983 1 -0.198359 -0.005882
				keys 1
					0 0 0.1 0.5 false
			2 2 1
				keys 1
				keys 2
				keys 1
					0 0 0.1 0.5 1
				keys 1
					0 0 0.1 0.5 false
				keys 1
					0 0 0.1 0.5 0 0
				keys 1
					0 0 0.1 0.5 0
	### sub-layers
	layer_type 1
		name "Layer 1"
		quality_flags 1020
		origin 0 0
		parent_bone -1
		visible true
		render_only false
		edit_only false
		face_camera false
		masking 0
		blend_mode 0
		camera_immune false
		dof_immune false
		### transforms
		translation
			keys 1
				0 0 0.1 0.5 0 0 0
		scale
			keys 1
				0 0 0.1 0.5 1 1 1
		rotation_x
			keys 1
				0 0 0.1 0.5 0
		rotation_y
			keys 1
				0 0 0.1 0.5 0
		rotation_z
			keys 1
				0 0 0.1 0.5 0
		flip_h
			keys 1
				0 0 0.1 0.5 false
		flip_v
			keys 1
				0 0 0.1 0.5 false
		shear
			keys 1
				0 0 0.1 0.5 0 0 0
		### layer effects
		noisy_shapes false
		noisy_lines false
		noise_amp 0.033333
		extra_lines 0
		gap_filling false
		fill_texture ""
		line_texture ""
		mesh
			points 4
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 0
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 1
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 2
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 3
			curves 1
				4 true
					0 true
						keys 1
					1 true
						keys 1
					2 true
						keys 1
					3 true
						keys 1
			shapes 1
					4
						0 0
						0 1
						0 2
						0 3
						false
							keys 1
								0 0 0.1 0.5 1 1 1 1
						false 0.004167
						false
							keys 1
								0 0 0.1 0.5 0 0 0 1
						false
						6.283185
						0.25
						true
						-1
						-1
						-1
			groups 0
	layer_type 1
		name "Layer 2"
		quality_flags 1020
		origin 0 0
		parent_bone -1
		visible true
		render_only false
		edit_only false
		face_camera false
		masking 0
		blend_mode 0
		camera_immune false
		dof_immune false
		### transforms
		translation
			keys 1
				0 0 0.1 0.5 0 0 0
		scale
			keys 1
				0 0 0.1 0.5 1 1 1
		rotation_x
			keys 1
				0 0 0.1 0.5 0
		rotation_y
			keys 1
				0 0 0.1 0.5 0
		rotation_z
			keys 1
				0 0 0.1 0.5 0
		flip_h
			keys 1
				0 0 0.1 0.5 false
		flip_v
			keys 1
				0 0 0.1 0.5 false
		shear
			keys 1
				0 0 0.1 0.5 0 0 0
		### layer effects
		noisy_shapes false
		noisy_lines false
		noise_amp 0.033333
		extra_lines 0
		gap_filling false
		fill_texture ""
		line_texture ""
		mesh
			points 4
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 0
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 1
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 2
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 3
			curves 1
				4 true
					0 true
						keys 1
					1 true
						keys 1
					2 true
						keys 1
					3 true
						keys 1
			shapes 1
					4
						0 0
						0 1
						0 2
						0 3
						false
							keys 1
								0 0 0.1 0.5 1 1 1 1
						false 0.004167
						false
							keys 1
								0 0 0.1 0.5 0 0 0 1
						false
						6.283185
						0.25
						true
						-1
						-1
						-1
			groups 0
	layer_type 1
		name "Layer 3"
		quality_flags 1020
		origin 0 0
		parent_bone -1
		visible true
		render_only false
		edit_only false
		face_camera false
		masking 0
		blend_mode 0
		camera_immune false
		dof_immune false
		### transforms
		translation
			keys 1
				0 0 0.1 0.5 0 0 0
		scale
			keys 1
				0 0 0.1 0.5 1 1 1
		rotation_x
			keys 1
				0 0 0.1 0.5 0
		rotation_y
			keys 1
				0 0 0.1 0.5 0
		rotation_z
			keys 1
				0 0 0.1 0.5 0
		flip_h
			keys 1
				0 0 0.1 0.5 false
		flip_v
			keys 1
				0 0 0.1 0.5 false
		shear
			keys 1
				0 0 0.1 0.5 0 0 0
		### layer effects
		noisy_shapes false
		noisy_lines false
		noise_amp 0.033333
		extra_lines 0
		gap_filling false
		fill_texture ""
		line_texture ""
		mesh
			points 4
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 0
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 1
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 2
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 3
			curves 1
				4 true
					0 true
						keys 1
					1 true
						keys 1
					2 true
						keys 1
					3 true
						keys 1
			shapes 1
					4
						0 0
						0 1
						0 2
						0 3
						false
							keys 1
								0 0 0.1 0.5 1 1 1 1
						false 0.004167
						false
							keys 1
								0 0 0.1 0.5 0 0 0 1
						false
						6.283185
						0.25
						true
						-1
						-1
						-1
			groups 0
layer_type 4
	name "Skeleton 3"
	quality_flags 1022
	origin 0 0
	parent_bone -2
	visible true
	render_only false
	edit_only false
	face_camera false
	masking 0
	blend_mode 0
	camera_immune false
	dof_immune false
	### transforms
	translation
		keys 1
			0 0 0.1 0.5 0.691157 0 0
	scale
		keys 1
			0 0 0.1 0.5 1 1 1
	rotation_x
		keys 1
			0 0 0.1 0.5 0
	rotation_y
		keys 1
			0 0 0.1 0.5 0
	rotation_z
		keys 1
			0 0 0.1 0.5 0
	flip_h
		keys 1
			0 0 0.1 0.5 false
	flip_v
		keys 1
			0 0 0.1 0.5 false
	shear
		keys 1
			0 0 0.1 0.5 0 0 0
	### layer effects
	expanded false
	group_mask 0
	depth_sort false
	distance_sort false
	skeleton
		binding_mode 2
		bones 3
				keys 1
					0 0 0.1 0.5 false
			2 2 1
				keys 1
				keys 4
					12 0 0.1 0.5 1.622775
				keys 1
					0 0 0.1 0.5 1
				keys 1
					0 0 0.1 0.5 false
				keys 1
					0 0 0.1 0.5 0 0
				keys 1
					0 0 0.1 0.5 0
				keys 1
					0 0 0.1 0.5 false
			2 2 1
				keys 1
				keys 4
					0 0 0.1 0.5 6.27039
					12 0 0.1 0.5 6.108772
				keys 1
					0 0 0.1 0.5 1
				keys 1
					0 0 0.1 0.5 false
				keys 1
					0 0 0.1 0.5 0 0
				keys 1
					0 0 0.1 0.5 0
				keys 1
					0 0 0.1 0.5 false
			2 2 1
				keys 1
				keys 4
					12 0 0.1 0.5 0.122427
				keys 1
					0 0 0.1 0.5 1
				keys 3
					0 0 0.1 0.5 false
					7 0 0.1 0.5 true
					13 0 0.1 0.5 false
				keys 3
					0 3 -1 -1 0 0
					7 3 -1 -1 -0.029763 -0.198319
					13 3 -1 -1 -0.029763 -0.198319
				keys 3
					0 3 -1 -1 0
					7 3 -1 -1 1.57079
					13 3 -1 -1 1.57079
	### sub-layers
	layer_type 1
		name "Layer 1"
		quality_flags 1020
		origin 0 0
		parent_bone -1
		visible true
		render_only false
		edit_only false
		face_camera false
		masking 0
		blend_mode 0
		camera_immune false
		dof_immune false
		### transforms
		translation
			keys 1
				0 0 0.1 0.5 0 0 0
		scale
			keys 1
				0 0 0.1 0.5 1 1 1
		rotation_x
			keys 1
				0 0 0.1 0.5 0
		rotation_y
			keys 1
				0 0 0.1 0.5 0
		rotation_z
			keys 1
				0 0 0.1 0.5 0
		flip_h
			keys 1
				0 0 0.1 0.5 false
		flip_v
			keys 1
				0 0 0.1 0.5 false
		shear
			keys 1
				0 0 0.1 0.5 0 0 0
		### layer effects
		noisy_shapes false
		noisy_lines false
		noise_amp 0.033333
		extra_lines 0
		gap_filling false
		fill_texture ""
		line_texture ""
		mesh
			points 4
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 0
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 1
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 2
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 3
			curves 1
				4 true
					0 true
						keys 1
					1 true
						keys 1
					2 true
						keys 1
					3 true
						keys 1
			shapes 1
					4
						0 0
						0 1
						0 2
						0 3
						false
							keys 1
								0 0 0.1 0.5 1 1 1 1
						false 0.004167
						false
							keys 1
								0 0 0.1 0.5 0 0 0 1
						false
						6.283185
						0.25
						true
						-1
						-1
						-1
			groups 0
	layer_type 1
		name "Layer 2"
		quality_flags 1020
		origin 0 0
		parent_bone -1
		visible true
		render_only false
		edit_only false
		face_camera false
		masking 0
		blend_mode 0
		camera_immune false
		dof_immune false
		### transforms
		translation
			keys 1
				0 0 0.1 0.5 0 0 0
		scale
			keys 1
				0 0 0.1 0.5 1 1 1
		rotation_x
			keys 1
				0 0 0.1 0.5 0
		rotation_y
			keys 1
				0 0 0.1 0.5 0
		rotation_z
			keys 1
				0 0 0.1 0.5 0
		flip_h
			keys 1
				0 0 0.1 0.5 false
		flip_v
			keys 1
				0 0 0.1 0.5 false
		shear
			keys 1
				0 0 0.1 0.5 0 0 0
		### layer effects
		noisy_shapes false
		noisy_lines false
		noise_amp 0.033333
		extra_lines 0
		gap_filling false
		fill_texture ""
		line_texture ""
		mesh
			points 4
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 0
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 1
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 2
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 3
			curves 1
				4 true
					0 true
						keys 1
					1 true
						keys 1
					2 true
						keys 1
					3 true
						keys 1
			shapes 1
					4
						0 0
						0 1
						0 2
						0 3
						false
							keys 1
								0 0 0.1 0.5 1 1 1 1
						false 0.004167
						false
							keys 1
								0 0 0.1 0.5 0 0 0 1
						false
						6.283185
						0.25
						true
						-1
						-1
						-1
			groups 0
	layer_type 1
		name "Layer 3"
		quality_flags 1020
		origin 0 0
		parent_bone -1
		visible true
		render_only false
		edit_only false
		face_camera false
		masking 0
		blend_mode 0
		camera_immune false
		dof_immune false
		### transforms
		translation
			keys 1
				0 0 0.1 0.5 0 0 0
		scale
			keys 1
				0 0 0.1 0.5 1 1 1
		rotation_x
			keys 1
				0 0 0.1 0.5 0
		rotation_y
			keys 1
				0 0 0.1 0.5 0
		rotation_z
			keys 1
				0 0 0.1 0.5 0
		flip_h
			keys 1
				0 0 0.1 0.5 false
		flip_v
			keys 1
				0 0 0.1 0.5 false
		shear
			keys 1
				0 0 0.1 0.5 0 0 0
		### layer effects
		noisy_shapes false
		noisy_lines false
		noise_amp 0.033333
		extra_lines 0
		gap_filling false
		fill_texture ""
		line_texture ""
		mesh
			points 4
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 0
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 1
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 2
					keys 1
					keys 1
						0 0 0.1 0.5 -1
				-2
				true
				1
					0 3
			curves 1
				4 true
					0 true
						keys 1
					1 true
						keys 1
					2 true
						keys 1
					3 true
						keys 1
			shapes 1
					4
						0 0
						0 1
						0 2
						0 3
						false
							keys 1
								0 0 0.1 0.5 1 1 1 1
						false 0.004167
						false
							keys 1
								0 0 0.1 0.5 0 0 0 1
						false
						6.283185
						0.25
						true
						-1
						-1
						-1
			groups 0
Lost Marble
This is actually working as expected, but I think a more detailed description of bone locking is in order. When you lock a bone, two things are really happening:
First, what is really getting locked is the tip of that bone's parent. For example, if you lock your foot on the floor, the tip of your lower leg bone (your ankle) is locked in place.
Second, the bone that you locked then tries to maintain the same angle if other bones in the chain move around.
Put those together, and there are two things that really get locked: the tip of the parent bone and the angle of the locked bone.
So, because of point #1 above, when you lock a bone it needs to have a parent. In your first example, you're trying to lock a bone with no parent which can't be done. Bone locking is designed to be used mostly with bones at the end of a chain: feet, hands, etc.
Toontoonz
Post by Toontoonz »
So now how does one get a leg to bend at the knee if the foot bone is locked?
The foot bone is locked.
The calf leg bone attached to the foot bone won´t move.
The thigh leg bone barely budges and moves the calf leg bone a fraction. The only bone that can be moved is the hip (parent) bone and it will budge all bones a bit. And when I move the hip bone the locked foot bone keeps its same angle, but it moves a little bit horizontally off its position.
Here is a graphic showing how much one can now bend a leg with the foot locked:
click to see larger.
In what situation would one want to now lock a bone? Nothing much moves in the IK change (other that the parent).
If I wanted to constrain the angle of the bone attached to a bone I would rather use Bone Constraints > Angle Constraints than the new locked bone system.
To me a locked bone has a different meaning. Locked means that bone will not move, it stays in place like it is cemented to the ground, but everything else can rotate around it.
But I guess I have the wrong understanding of what locked means.
However I can´t figure out what situation one would use this new locked bone system - it freezes up everything in the IK chain.
I want the character´s feet to stay in place (locked) on the ground (keeping their position and angle locked) while the rest of the character moves around.
How can one now do that in Moho?
ulrik
Post by ulrik »
It's working, look at the picture
this is the parent-child chain: leftmost little bone - lowest bone (locked) - the blue one over that - the red one - and the top bone.
At frame 0 the locked bone is not locked but after that it stays locked and you can freely rotate, scale and translate the other bones in the leg.[img]/Users/ulrikboden/Desktop/lockedbone.png[/img]
ulrik
Post by ulrik »
ahhrghh...how do I put an image here?....hmmm
ulrik
Post by ulrik »
here's the image:
Rasheed
Post by Rasheed »
ulrik wrote:ahhrghh...how do I put an image here?....hmmm
image shack perhaps?
