Export as flash file problem (Possible bug)
Star-Peace
So this is very simple, I found out that if you use the cloud brush that anime studio gives you under brushes, make a cloud, and you animate that cloud floating up and down.... once exported as a flash file, that floating cloud turns into a perfectly circular brown ball floating up and down...what even!? If it helps any, It's on a vector layer... Is this a Bug or just a goof up on my part? Thanks! ^_^
Also, I'm using Anime Studio Pro 11
- Víctor Paredes
Re: Export as flash file problem (Possible bug)
Check the user manual (under the help menu). Flash export is covered from page 375 to 380, there you will find what you can and can't export and also some tips for better results with the swf file.
Star-Peace
It says on page 376 that vector layers are accepted, I'v exported much more complex stuff into flash files, You'd think it could accept a simple cloud. I'v thoroughly read 375 to 380, is this a bug or what? (The cloud layer isn't optimized but never had trouble exporting other things unoptimized, could that be it? idkVíctor Paredes wrote:Check the user manual (under the help menu). Flash export is covered from page 375 to 380, there you will find what you can and can't export and also some tips for better results with the swf file.
- Víctor Paredes
Brushes won't be exported to Flash.
Star-Peace
huh...well I guess that makes sense, Thank you Victor for your help! I will make some changes
Have a good day
