Changing Line Widths
Locked
xian
Post by xian »
I have been experiencing a problem with my line widths.
If the width is set in frame 0 (zero), it changes once I am in the animation.
It seems to be a variable problem. Sometimes the lines are thick and other times they appear thin.
This makes it very difficult to produce consistant lines and it is extra-frustrating when you change them all, only to find that you must do it again after rendering.
I have turned off Scale Compensation in all of my layers, because I thought this would keep my lines uniform despite any camera movement and position in the Z-axis.
Has anyone else experienced this? Perhaps there is a simple solution that I am overlooking. Any help is appreciated.
Can I get a blue spot?
Rai López
Post by Rai López »
Are you reffering to :arrow: THIS
xian
Post by xian »
Not really Ramon.
There is no variation in line width on the outline, it is all the same width.
However, at frame 0, the width appears different than later in the animation.
Lost Marble
Post by Lost Marble »
Are you scaling the layer in question? As a layer gets smaller (or bigger), the lines in that layer get thinner (or thicker). This is called Scale Compensation in Moho and is intended to maintain the overall "weight" of the lines. If you don't want this to happen, turn off the "Scale compensation" checkbox in the Layer Settings dialog.
Locked
