ASP 9.5 Bone points option grayed out
mcallegari
Post by mcallegari »
I'm trying to apply two bones to one image by using bone points but the point options aren't available. Anyone have an idea on how to fix this problem?
Thanks!
Distinct Sun
Re: ASP 9.5 Bone points option grayed out
Post by Distinct Sun »
It could be that you are not on Frame 0 ?
Or is the bone already bound to a layer? If so, or you are unsure, just release layer and Points and try that.
"All colors are the friends of their neighbors and the lovers of their opposites."
Marc Chagall
Uhm, if I understand well, you simply can't apply "point" options because your are not on a vector layer, but an image layer.
If you want to bend a single image with two or more specific bones, you must select that image layer, then select the bones you want and then go to the menu Bone>Use selected bones for flexi-binding.
Now the image will be bent by those specific bones' strength.
Distinct Sun
Víctor Paredes wrote:Uhm, if I understand well, you simply can't apply "point" options because your are not on a vector layer, but an image layer.
Nice catch Victor, I overlooked that. My posted options would have only worked with vector.
Marc Chagall
