Rotate at the same speed
- uncle808us
I want to rotate a layer but I don't want it to speed up as it goes from the start to the end of the frames. How can I do this right now I'm using linear but it starts slow and speeds up towards the end. Is there a way to have the same speed thru out the animation? Thanks
http://uncle808s.blogspot.com
Re: Rotate at the same speed
Between two linear keyframes the motion will not accelerate and will be a constant speed. Now if you are using more than one frame, they would have to be linear and have the same number of frames and distance to move between them for a constant speed.
- uncle808us
My error I did not set the first keyframe to linear. Sorry and thanks for the reply and the answer.
