Broken Layer references Cure
- djwaterman
I just examined a number of my character scenes and noticed that the layer references were all broken, I don't know why, does this happen once you have any sort of animation in a project?
Anyway, the only way I could restore these was to select each reference layer on frame zero and right click over the point transform and point curvature icons to the left of the time-line and click on the "sync channel to original" that pops up.
If you needed the layer to reference other properties, like line thickness of fill color or whatever, you'd have to go down the list of these and restore them also.
Is this an expected behavior of how ASP works?
It's strange because in the layers menu these referenced layers are all pointing to the original yet in the timeline it says "not referenced".
Other character projects are still okay, they are ones that never had any animation applied (perhaps there's something in that).
Re: Broken Layer references Cure
You're not alone, I noticed the same issue. Randomly all of the channels in some of my reference layers will lose sync. To make matters worse, you can't sync them again using the reference dialog options, you have to go through every channel and manually sync each channel.
I'm trying to find a way to replicate the problem and then I'm submitting a bug report.
- digitalhyper
I just wanted to chime in and say that I reported something like that to support. In my case, I created a character and reference layered the entire character and flipped it applying a color to the whole thing to treat it like a shadow. I then had another scene open and wanted to reference in that character and once I did, the reference layer broke. So I ended up just importing the character as a reference, then doing my layer reference for shadow purposes. Just stinks to have to set that up for each scene, unless I save the scene as a new one and wipe the animation to start the next scene.
Jamie Byers Animation Generalist
http://www.digitalhyper.com
Windows 11 PRO 64 bit
12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz, 128 GB Ram, Nvidia GeForce RTX 4070 & RTX 4080, Wacom Cintiq 16 with Loupedeck Live
Moho Pro 14
After Effects, Premier, Illustrator, Photoshop, 3DS Max, Mudbox and Mocha Pro
Moho Pro 14
- neeters_guy
Thanks for the tip. I was experimenting with selgin's head turn and my reference layers broke for some reason (there were keys on all the channels in frame 0). It's tedious having to go through all the channels, but at least I can fix it now.djwaterman wrote:Anyway, the only way I could restore these was to select each reference layer on frame zero and right click over the point transform and point curvature icons to the left of the time-line and click on the "sync channel to original" that pops up.
My reference layers are also breaking. Anybody find a solution for this?
- Víctor Paredes
Could you explain the steps to reproduce your problem or post a file to check it?RichardU wrote:My reference layers are also breaking. Anybody find a solution for this?
Also, what version of Moho/Anime Studio are you using?
Thanks
This was six months ago with whatever version was current at the time (11?). There were no steps required -- happened just about every time I opened the file. I don't have that version or that file now.Víctor Paredes wrote:Could you explain the steps to reproduce your problem or post a file to check it?
Thanks,
Richard
- Víctor Paredes
Thank you,RichardU wrote:This was six months ago with whatever version was current at the time (11?). There were no steps required -- happened just about every time I opened the file. I don't have that version or that file now.Víctor Paredes wrote:Could you explain the steps to reproduce your problem or post a file to check it?
Thanks,
Richard
For some reason, I thought this message was from today...
JimmyMcNulty
Does anybody know, if this is (still) a general issue?djwaterman wrote:I just examined a number of my character scenes and noticed that the layer references were all broken,[...]
I'm testing the possibility to switch from Anime Studio 8 to Anime Studio 12 (Moho again) for the second season of a big TV series. Marco Polo season 1 episode 1 trailer (sorry, just a german version): https://www.youtube.com/watch?v=HwS0MvklScw%20.
I encountered the problem with the broken layer references in my test file, after updating from Moho 12.0 to Moho 12.1 (because of another issue). After a quick search, I found this thread and this is really bad news. If this is a general problem, it's impossible to update. I need the layer referencing, to reproduce MorphDials Script functionality from older Anime Studio versions (controlling all the heads in all character views from one central layer) and still keep the file size down (I think the MorphDials script was way more powerful for this than smart bones, but this is a completely different topic). Besides a central expression control layer, referencing is also nice, to control the hands in every character view from a central hand layer.
Coming from a Autodesk Maya background, referencing, in my opinion, is a very powerful feature. But instable, this could mess up the whole production and we really have to go with the old version of Anime Studio. With all drawbacks.
If anybody could give me some information on this issue, this would be very nice. I will also contact the support, but I will do some further testing as well. Btw. I can't post any files, because of non-disclosure agreements.
Johannes
edit:
Company Showreel (also some Marco Polo around 3.33 and another Anime Studio project around 3.09 (Fennel Vennel 19)): https://www.youtube.com/watch?v=hnXZyNy-0_M
HI Johannes,
Could I suggest that even if you didn't use references that Moho 12 is a way better option than earlier versions for many, many other reasons.
I have been using references for a short film with well over 100 scenes and it has worked fine.
If there is a problem with a specific function, then you might need a temporary workaround , but no doubt it will be found and fixed.
If it being used on a series then I'm sure (just guessing) any bug you report would get attention very quickly, the devs are very considerate and take the concerns of users very seriously in my experience.
Also the betas are pretty fastidious , go with Moho!
BTW was that first series done in ASP or Maya?
Love the design and colours, Moho could help definitely with foot slipping and just make the rigs work a bit more flexibly.
Oh , very impressive reel btw. Wow
JimmyMcNulty
Thanks for the information about referencing. Right now, it looks good for me too. Maybe it was a problem with the update from Moho 12.0 to 12.1.chucky wrote: I have been using references for a short film with well over 100 scenes and it has worked fine.
I know the support is very helpful, but bigger problems in the middle of the production would be a very expensive issue. With the start of the production, a lot of people rely on a smooth running production schedule. So 40-50 people can't work for days or weeks? Fixing hundreds of animation shots? No, thank you. This is something, I don't want to encounter.
That's why I'm a little sceptical, because of a thread like this. But, as I said, it's looking good right now.
The first link (first season of marco polo) was done in Anime Studio 8.2, but there is some 3D involved. As I remember, the 3D was done in Maya.chucky wrote: BTW was that first series done in ASP or Maya?
Wow, Thank you very much brother, I struggling so much, I always open up dialog and edit the manual every time a layer reference is broken. Now it more simple, Once again thank you so much, you a lifesaver.djwaterman wrote: ↑Tue Jun 16, 2015 6:05 am I just examined a number of my character scenes and noticed that the layer references were all broken, I don't know why, does this happen once you have any sort of animation in a project?
