Bone Crazy ;-) .. need some help.
Animark
Post by Animark »
Hello,
I was a little bit crazy today while trying to rig a simple character. I made some mistakes when connecting some bones to layers, switched to binding points to bones, released some points and so on ... A little bit like clicking and don't thinking.
However. I ended up with some bones which I am not able to bind to anything anymore???
So is there some good workflow to reset all layers and bones to their original (untouched) condition?
I tried a lot with the options under the bone menu (Release points, flexi-bind points, ...) but had no luck at all.
Many thanks!
Animark
Re: Bone Crazy ;-) .. need some help.
Post by Animark »
Now, I think it has something to do with the little red point on top left of the layer icon. All problem-layers have that dot. At one layer I was able to remove the point after using the "Release Layer" command. After that the layer works fine. But I am not able to do the same with the other layers. Any hints?
And i am using ASP 10.1.1 pro.
