v5.3 render problem
Locked
Sine
v5.3 render problem
Post by Sine »
I'm having problem rendering avi in V5.3.
After rendering the last frame, MOHO disappears on me and leaves me with a broken avi. Anyone else experiencing this?
Using XP pro.
Sine =)
T
Post by T »
Did a very simple animation test, rendered 72 frames as AVI with "Full Frames Uncompressed", and it worked fine.
Are you using compression? If so, which?
"T"
One who makes no mistakes, never makes anything.
www.flyingmcdavidbros.com
Sine
Post by Sine »
Found out what went wrong. I had a wav file sountrack that MOHO didn't like. Previously, I could even load an avi as a soundtrack but v5.3 will only take wav. I had to rip the audio from the avi and since the avi was a DV footage, the wav file was a 48KHz 16bit stereo format. Downsampling it to 44KHz and below solved the problem.
Thanks for trying it out.
Sine =)
Locked
